Miners rule analysis
Hi all, i want to do miners rule analysis for gear. So that i have the following input parameters:
1. number of teeth (14)
2. Heat treat : case carburized
3. Operating torque
4. Operating speed
5. Operating time
6. Operating stress
7. Allowable stress
with those parameters, would like to know the following output parameter values:
1. Operating cyles
2. Cycles to failure
3. Life factors
4. Cycle ratio
could anyone provide me the formulas for the above output parameters with the above input variables.
thanks
3. Operating torque
4. Operating speed
5. Operating time
6. Operating stress
7. Allowable stress
1. Operating cyles
3. Life factors
4. Cycle ratio
thanks
RE: Miners rule analysis
ISO 6336-6, Calculation of load capacity of spur and helical gears – Part 6: Calculation of service life under variable load.
If you can track down anybody associated with the draft review process you might be able to get hold of a copy.
