galling in 6061 threads
We have an intermittant problem with thread galling and seizing between mating 6061-t6 aluminum parts (an oil filled container and its cap).   I know that this is a tricky situation, but there does not seem to be an option for us.
The pieces in question are of a diametrical range between 2 and 7 inches.  We are not using the threads with any load- they are just used to hold the cap onto the container, and an o-ring surface in place. (Parts for sub-sea ROVs). The parts sometimes sieze when the cap is being lightly turned onto the body.  We are using a 16 pitch thread cutter with our CNC process.
Has any one ever found a fix to this problem? Is there any coating that we can use to help eliminate the siezing?
thanks
RE: galling in 6061 threads
Graphite, Molykote or Never-Seez will help.  Teflon pipe tape will help.  Anodizing one of the parts will help.  Brass plating the threads on one part will help.  A little of the o-ring lube would help.  Anything but aluminum on aluminum will be an improvement.
Mike Halloran
Pembroke Pines, FL, USA
