on-demand power steering
Hi
I'm in to tinkering big-time. I would like to make an electric on-demand power steering system for my car. I want to reduce the drag of the full-time power steering pump. I know it doesn't use that much fuel but I want to have as much fuel economy and power from 'my precious'. A lot of my driving is highway - very straight. I don't need the power assist here. I can mount a lawn tractor starter motor to a power steering pump. It would be activated when the wheel is turned more than, say 10-15 degrees. So, would the starter motor have enough torque and rpm to run the pump? Would this be responsive enough for most situations? How could I make this work?
RE: on-demand power steering
Otherwise you'll need at least 1 hp, at the right speed.
Cheers
Greg Locock
Yes, you'd need a solenoid controlled valve to isolate the pump when it was not rotating.
Actually this seems like a pretty reasonable solution, I'll have to ask the boys at work why no one uses it.
Otherwise, as you say, you'll have to find the right motor and gearbox combination. In some ways you are less constrained than the OEMs, so you may be able to come up with a more practical (ie less powerful) system than they have. The major constraint on PAS sizing is called catch-up, where the customer expects to be able to spin the handwheel round and expects not to feel any significant resistance.
Cheers
Greg Locock
Cheers
Greg Locock
