Problems wrapping a curve onto a spherical surface
I am trying to wrap a datum curve consisting of text onto a spherical surface.  When I select the spherical surface I get an error message saying the surface can't be developed.  I can wrap the curve onto an extruded surface.
Any ideas please, or perhaps a work around?
Many thanks
Dave
RE: Problems wrapping a curve onto a spherical surface
Do a search on text and curves....this is a good thread thread554-98945
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Wrap requires a surface that can be flattened. This basicly means it can only have curvature in one diraction.
Projection will work and there maybe something in the warp tool to to do it.
hi,
once I have the same problem, but it was with a coca cola logo.
I manage very well doind the following:
I create a cone inserted on the sphere
I've wraped the coca logo on the cone
then I've projected the result of the wrap on the sphere.
Of course this is not 100% correct but the result was pretty good
regards
luiscl, that's a good idea.
Wrap the curve onto a developable surface, then project that onto the undevelopable one. For a Sphere, I just tried wrapping a logo onto a cylinder, and then projecting it onto a sphere, with good results...
