sheet and plate
sheet and plate
sheet and plate
What is the difference between sheet and plate?
Example:
ASME SEC II B SB-171 Specification for Copper-Alloy Plate and Sheet for Pressure Vessels, Condensers, and Heat Exchangers
RE: sheet and plate
ASME definition:
Plate: 3/16" and over thk and over 10" wide.
Sheet: under 3/16" thk and 24" and over wide.
RE: sheet and plate
I also looked it up. SB-171 spec gives plate as 3/16" and over thk and over 12" wide not 10".
RE: sheet and plate
Sorry!!!
RE: sheet and plate
A sheet goes on your bed.
A plate goes on your table.
Brian
