Safety relief valve vent piping
Anybody know who are the companies that specialize in the supply of safety relief valve vent piping systems? Or is this just typically handled by general piping contractors?
GB
GB
RE: Safety relief valve vent piping
a. minimum back pressure or back pressure is considered in valve sizing.
b. work place safety. people will not be hurt by sudden blow of air or any other fluid.
c. don't let condensate stay in the pipe.
d. if the fluid is liquid, it should get gack to the process or to a drain (for water).
e. if it's steam, consult a thermo piping engineer since you have to consider not only the above a, b, c but also the stress impact on the piping.
Here's a link for Mustang Engineering. They have an excelant reputation for the kind of work you are describing.
http://www.mustangeng.com/content.aspx?process
Good Luck,
NozzleTwister
Houston, Texas
Steamguy2
www.SteamPlantEngineering.com - Discussion & resources for professionals in the Power Generation Industry
