How to use a UMAT
How to use a UMAT
Hello, I will have to use a UMAT. - it would be possible that somebody indicates the procedure to me to make use of it? Thank you in advance.
RE: How to use a UMAT
If you mean the former then there is no way on God's green earth that this -- or any other -- forum will help you to the extent of providing a step by step procedure. Go speak to ABAQUS about it (and even by their own admission they don't fully understand them). If you mean the latter, then the ABAQUS documentation has a very good section on using UMATs.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
abaqus j=jobname user=umat.o
The ABAQUS input file will contain the material parameters. Including these parameters is done through the *USER MATERIAL keyword in the input file:
CODE
*HEADING
Test
*NODE
1, 0.0, 0.0, 0.0
2, 1.0, 0.0, 0.0
3, 1.0, 1.0, 0.0
4, 0.0, 1.0, 0.0
*ELEMENT,TYPE=CPS4,ELSET=ONE
1,1,2,3,4
*SOLID SECTION,ELSET=ONE,MATERIAL=FIRST
*MATERIAL,NAME=FIRST
*DEPVAR
80
*USER MATERIAL,CONSTANTS=29
1,3,1.5E5,0.33,90000.,100.,5.5221,0.1E+22,
90.44,32.71728773,50.6474693,4.000,0.10E+01,3142132918629.0,0.10E+22,1.99939
2.019,1.993,4.3444,1.7660,2.91162,0.49955D-03,0.499684D-03,0.5D-D03
67030.5,33793.86,1835.45953,0.0, 0.0
*BOUNDARY
1, 1,2
2, 2
4, 1
