Which PLC
Which PLC
I am unsure which PLC to go for a job that has 20 inputs and 20 outputs (simple sequence needed), software cost seems to become a major factor as I only do several projects a year.
I have very little PLC experience, I have used the AB05 and Mitsubishi FX series many years ago and recently did several project using the Mitsubishi alpha 2.
Siemens S7 series looks good with cheap software, I have downloaded the demo software and it looks more difficult than Mitsubishi software.
Morris
Morris
RE: Which PLC
We use them in our stamping plants for assy equipment.
http://web2.automationdirect.com/adc/Home/Home
RE: Which PLC
Morris
RE: Which PLC
The prices may make the job profitable, Thanks
Morris
RE: Which PLC
If you are still considering other options, we offer free software with our controllers.
You can learn more at our web site - www.entertron.com
Hope this helps.
God Bless,
Stephen
RE: Which PLC
I have no vested interest here. Just have used Mitsi's for some years.
Life is what happens while we're making other plans.
Wally
RE: Which PLC
What's wrong with Mitsubishi FX1S?
RE: Which PLC
RE: Which PLC
RE: Which PLC
This is my first post to the forums, and hope to gain some valuable info myself. I have found this program most valuable if you want to create your own ladder diagrams and create the necessary program for running PLC's.
C:\TRiLOGIEDU\TL5\public\help\content.htm
Geoff (Sydney Australia)
RE: Which PLC
The programable relay is about $300.00
Plus a expansion unit for another $150.00
http://www.moellerusa.net/
I have no intrest in Moeller just their relays to automate equiptment.
RE: Which PLC
They have a good helpdesk.
RE: Which PLC
But to the point:
Do check out the TWIDO.
http://www.modicon.com/PLCIO/twido/
Look at the starter packs! They come with everything including the software for a couple hundred bucks. I believe you can even program it thru Bluetooth from a laptop(no hookup).
They are made specifically for jobs with lots of "sequence" that stand alone. oem applications.
RE: Which PLC
RE: Which PLC
I forgot to mention that the plc software is $49, next to free and reminds me of RSlogix for AB stuff only different. It is simple to use and the plc only has 55 straightforward instructions; but, seems to do everything we need.
RE: Which PLC
I then opted to use a solid state relay between the output and stack light.
best regards, plcsavvy
RE: Which PLC
Shame because the PLC is OK for simple jobs.
RE: Which PLC
Customer demanded Modicon anyway so I went with the Momentum.
