PH150 piston rod
PH150 piston rod
I come across a piston rod material of PH150 recently, but am not so familar with it. Would anybody give some clue on the mechanical property of this material? Thanks.
RE: PH150 piston rod
This dia. 4" rod is for a cylinder, customer requested this material because it is scratch free. We wish to know more about it, so that our quotation would be ok.
Usually scratch free rods, piston or otherwise, are surface hardened and hard chrome plated.
If you could comeback with the end use, like for a hydraulic cylinder, compressor, or a guide rod, this might help jog someone memory.
