Axial compression of a silicone cyclinder
I am looking for the calculation that will tell me how much the diameter of a solid silicone cylinder will reduce under hydrostatic compression. The closest I have found so far is this:
http:// www.engine erstoolbox .com/doc/e tb/mod/sta t1/pressur e/pressure _help.html
but it requires an inner diameter. If no such calculation is available, is it acceptable to use an extremely small value for the ID instead?
Any help would be appreciated.
cuberille
http://
cuberille
RE: Axial compression of a silicone cyclinder
