Calibration / Verification of Indicator Gauges
Is there an ASTM standard for verifying the readings from an indicator gauge?
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
RE: Calibration / Verification of Indicator Gauges
If there is one, I believe it would be ANSI with traceability to an NIST Standard.
Alan M. Etzkorn
Project Develpment Engineer
Wabash National Corp.
www.wabashnational.com
Indicator of what?
This is an issue of calibration and traceability.
For some devices there are standards for calibration methods.  For most you are allowed to write your own, as long as you can prove that it works.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
EdStainless,
The indicator gauges I am talking about are dial or digital deflection indicators with required accuracy of both 0.0001 and 0.001 inch.
I should also throw in dial calipers. We need to be accurate to 0.001 inch for other ASTM methods.
Jeff
www.ttlassoc.com
I believe US standard accuracy grades and tolerances for pressure gauges are set forth by ASME B40.100-1998:
Pressure Gauges and Gauge Attachments
American Society of Mechanical Engineers
10-Dec-1998
ISBN: 0791825701
David Baird
mrbaird@hotmail.com
Sr Controls Designer
EET degree.
Journeyman Electrician.
