Creating own tool library
I want to create my own tools,holders(like end mills and Tool holders while using NX3 CAM) and want to save them so that I can use them again and again rather than filling every field again and again. Anybody knows how to do it in UG NX3?  Thanxs!
RE: Creating own tool library
There are text files that define feeds, speeds, tools, materials and other parameters under the CAM directory. UG can load data from these files and you can edit them to add your own tools. You can also set up templates that consist of work material, tool parameters and feeds that can be loaded from a master template file.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Thanks for your reply Ben! I looked at those text files and I think it will be a big job to change those files. How hard is to make template.Actually I am not familier with temlate files.Could you please tell me the procedure in detail how to make templates for custom tools and holders.I shall be highly thankfull to you. Thanks again
Amit
