Solidworks Sketch Help ?? ?
How do I make solidworks not rotate the view one-eighty, from the view that I orginally want to draw on, I really dislike using the alt and right arrow keys to draw on the orginal view that I have picked?
Printed Circuit Board Designer
Salt Lake City, Utah
Stangs rule!
RE: Solidworks Sketch Help ?? ?
Try: Tools/Options/View Rotation
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Flores
It worked !!
I click on the sketch view I wanted and I pick the edge the I want to be top and pick top icon, in the standard view icon button and it did what I wanted the view to do !!
Thanks guys !
Stangs rule!
You know it never fails to amaze me the
hidden secrets that I still learn about
SW. Great tip! You get a star!
Jeff
The catch to using this tool is that there must be some geometry in the sketch, and no external relations present to rotate it.
Jason
I've used what Gildashard mentions above mostly cause I find it easier to sketch a point and hit rotate if I was modeling quickly, because you can fix it after the fact more easily than canceling the sketch and repicking references.
Michael
