defining the 3rd intercept point for an amplifier
         I am after information regarding defining the 3rd intercept point for an amplifier I am designing.  I understand how to test it using two frequencies but don't know if there is a way I can specify it for design purposes based on some calculated values.  i.e.  I wish to specify a target value for a design specification.  Any information would be much appreciated.
Mike
RE: defining the 3rd intercept point for an amplifier
There is a wealth of information available by way of a google search.
  http://www.google.com
and then enter...
  third order intercept point
You probably already know that this parameter is an extrapolation and is not directly measureable.  In most cases you would "fry" the Unit Under Test (UUT) input long before you put in sufficient power to reach the TOIP.  An example would be a cute little MMIC amplifier with a TOIP of +40dBm (10 watts - YIKES!).
Have a good day.
J. Harvey
Ottawa
