Vibration meast. in Hor. & Vert. directions ; why?
What is the significance of measuring vibration in both horizontal and vertical directions when both are radially transmitted?
Vibration meast. in Hor. & Vert. directions ; why?Vibration meast. in Hor. & Vert. directions ; why?(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Vibration meast. in Hor. & Vert. directions ; why?
Pure imbalance with equal stiffness in both directions may generate approximately equal vibrations in both horizontal and vertical directions.
The dynamic stiffness may be radically different in the horizontal and vertical directions and each direction also has different resonant frequencies. Sometimes 1x is higher in the 1x direction and 2x is higher in the vertical direction due to resonance at one of those frequencies in one of those directions.
Misalignment can generate a number of complex patterns:
One is an oval-shaped orbit which may have it's access in either plane (H or V) or in some 3rd radial plane in between.
Starting with two readings gives us the info we need to start to sort thru some of the above possibilities and more. Additional info is sometimes needed (phase relationships). Probably most important, these numbers allow us to begin to visualize the way the machine is moving in space and time.
You need to know what levels of vibration are in each plane; horizontal or vertical. By using vectors, the counter measure for dynamic balancing can be calculated. Another reason - take for example a shell bearing on a modeartely sized fan. The bearing might be out of round (or oval) which would give higher levels of vibration in the major axis of the ellipse than on the minor axis. The different planes can indicate looseness in particular areas.
Do hope this brief explanation helps.
Langahl
