Less Aggresive Oxide Remover for Stainless Steel
We're having a problem with some diamond drawn stainless steel wire for medical instrument use. The straightening process of the wire scratches the surface, usually unpercieved by the human eye. The material itself is very hard and needs to have a hole drilled into it, therefor the ends are annealed so the material is soft enough to drill. The annealing process causing oxide to build up on the ends, and because its used in medical instruments it needs to have a uniform bright finish. The discoloration is corrected by immersing the ends in an oxide-remover called Ox-Out. The problem we are having is that the Ox-Out is etching the material where it was scraped by the straightening process, giving it a look of spiral tattoos. Due to budgeting problems we cannot add extra steps, such as polishing, to remove the spirals, or we can't change the current process that we have now. We are looking for a less aggresive Oxide remover that will clean off the ends, but not etch the scraps. Does anyone have any suggestions?
RE: Less Aggresive Oxide Remover for Stainless Steel
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
#1 - Reduce the immersion time.
#2 - Reduce the temperature of immersion.
#3 - Dilute the OxOut 536.
Good luck,
Latexman
If you want a true "bright anneal" use up to a 5% H2/95% Ar mix.
