CFPP and corresponding ambient temperature?
I'm working on diesel fuel characteristics. I have data about some samples and try to decide if the values are proper or not to use as automobile fuel in different countries. So my problem is about CFPP (cold filter plugging point). I have the CFPP values of these samples and should decide if they are with in the acceptable limits in a specific country. So, i need the lowest minus temperatures (or average minimum?) of countries to compare with CFPP. How can i obtain these temp. information about countries and what is the criteria/tolerance to decide the CFPP is enough or not?
