Printing with construction lines and hidden line.
How do I print the drawing with construction lines and hidden lines such as holes not seen at the particular view?
RE: Printing with construction lines and hidden line.
Are you using V4 or V5..
I am using V5R13.
OK you go to the view properties and deselect 'hidden lines' and '3D points' and '3D lines '. Try changing your selections in the graphic properties box of the view until you get what you want
Sorry I ment visualisation
A great help in time.
