piping layout for reciprocating equipment
hi ,would you know anybody,
example about piping of reciprocating compressör frequency, type of support for reciprocating compressör
RE: piping layout for reciprocating equipment
what is the cause of vibration when inlet pipe of steam turbine  vibrates?
Hi ahaq
Thank you for your response.
This is a electrical compressör. Inlet & outlet prosess line of vibration come from two main sources which are dynamic from compressör pulsation & thermal. Compressör has two stage. 1. stage 2 kg/cm2g ,6 kg/cm2g; -20 °C,70°.       2. stage 5.9 kg/cm2g,24 kg/cm2g & 60°C,142°C).
