over-frequency protection
My 15 MW steam turbine driven set tripped on over-frequency( 51 Hz 5 cycles for a 50 Hz operation m/c )and some couple of hours after my electronic vibration transducer failed. The power supply of the transducer failed.The transducer operates on 240 V 50 Hz supply and is fed via a UPS. It is also worth mentioning that for about four minutes before tripping, the TG set was operating in island mode with a frequency between 50 and 50.9 Hz.
Is the failure a mere coincidence or could it be linked with the high frequency operation.
I believe that the over frequncy setting should be at 50,5 Hz for 10 cycles duration maximum.
Any comment ?
Bob
Any comment ?
Bob
RE: over-frequency protection
We know that a relatively high frequency result in lower impedance for capacitive circuit consequently in higher current flow.
