ID clearance U-tube Heat Exchanger
I need to carry out a drift test to verify the minimum ID clearance (parlicurarly in the bended portion of U-Tube bundle)by pulling a mandrel (ball) of known size through a lenght of heat exchanger tube.
The question is that I do not know the formula to be used for the determination of the size of the mandrel (ball) and the standard from which has been extracted.
Thanks for your help
V.Federella
V.Federella
