HELP!_modelling an inlet tract within block...
Hi, I am a newbie with Solidworks so bear with me....
I am trying to model a cylinder head with Solidworks 2001+.
My problem is that I cannot construct the inlet/exhaust tracts within the cylinder block (a simple cube).
I have tried to use the sweep function, but that only produces a solid. I want to extrude the shape within the block. The tracts are typical curved paths.
How could I model the tracts. It is very frustrating!
sughew
sughew
RE: HELP!_modelling an inlet tract within block...
You will have to construct it using surfaces most likely, but it's been so long since most of us used SW01+, I'm sure our way of thinking will not work as well, since the version you are using is way limited then what we use today.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Converting old 2d paper drawings into solid models is also difficult because some cross sections that can be drawn in a 2d view do not connect in 3d, or SW will refuse the operation. Some curves are too sharp for a sweep or loft to follow. A lot of it was left to the pattern maker before, but SW does not have an icon for blend or file to fit.
EngJW: care to show me a pic of one of the drawings that you weren't able to use in a loft?
I got some really nice powerpoint presentations I found on the net showing exactly how to convince SW to produce the lofts the way you had intended. Check out the "Curvy stuff" tutorials.
The URL: Dimonte Group tutorials
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
I don't have anything that I can easily get to but typically it would be a round cross section lofted into a square or rectangular cross section. The round one would have an OD and ID (for the port wall)and the other section would have a wall of the same thickness.
This would generate an error message, something about using a single closed profile. I get around it by lofting a solid port for the outer wall and then a cut loft for the inside. It is a lot of extra work. It might just be my lack of knowledge or experience with this.
Thanks for the link. I will take a look at it.
