Need small cheap xducer
Hello all:
1st post.
I am looking for help in finding a manufacturer of inexpensive (<$10), small (5-10mm diameter, 5-10mm length) ultrasonic transducers in large volume (>10,000/yr.)
Desireable output would be of the order of 10 microns and 1W of continuous power.
RE: Need small cheap xducer
AtResonance,
I know that PCB makes transducers with a resonance freq of 1MHz.  They are not quite near your $10 requirement, but if you call them and talk to them they might be able to help you out.
I would also recommend doing a search using Google, you should be able to get many contacts with phone numbers.
Fred
