Curving HSS sections
An architect has requested a curved rectangular HSS 8x3 (curved against the 8" depth) with a 20 ft radius. I have checked with a few steel fabricators and non can accomplish this. Any suggestions (that will not be too costly to do)?
RE: Curving HSS sections
The only suggestion that I would have is that if you can't find anyone to do a 20' radius with a tube, you could build up the section out of flat plates. In fact if you have a steel detailer that you use a bit, they could probably price this for you for nothing: then tell the architect how much it costs and tell them either live with it(i.e. pay for it) or change their detail.
Doug
a torch and welded together. How long a segment
is required?
Just my $.02 worth.
Carl Bauer
www.bauerconsultbotswana.com
