Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I always seem to find what I need in previous threads without starting my own. I have started a couple but that's it..."
Geography
dkyuss (Industrial)
29 Jul 05 15:05
I am attempting to bond ceramic tiles to a steel backing that will be put into service in a very low pH environment (0.01 pH  phosphoric acid).  Bond strengths must be at least several mPa an the adhesive must retain some flexability.  Any products, ideas or suggestions are greatly appreciated.
Thank you in advance.
unclesyd (Materials)
29 Jul 05 23:17
You didn’t mention temperature or the presence of any organics or area to be covered so this is the first try.
Here is a company that might than likely be able to fill your needs.   We have used their products with very good results.  Give them a call.
They are a lot of other companies that make acid proof cements used for lining tanks for wastewater both acidic and basic.
http://www.sauereisen.com/c_prod/c_resist.htm
Close Box
Join Eng-Tips® Today!
Join Us             Close
