modification of merged part
I am attempting to do some mechanica analysis on a complex pro-e part that was created using merged objects and numerous hole pattens that have significant instances. I need to simplify the part so this analysis can be done. I have saved a copy of this part and called it something generic so that it will not actually modify the part that needs to be procured. I want to individually select features both within the merge and in the top level part model by clicking on the feature in the illustration window then deleting it from this avenue. Does anyone know of a way to achieve this with out having to open up all the pattern tables and going back to the original merged parts? Thanks for the Help!
ProEdj
ProEdj
RE: modification of merged part
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Best regards,
Matthew Ian Loew
