Where buy/order personalized engineering pads?
I know this doesn't fit into an engineering question but I just went solo and wanted to have my own name on the computation pad rather than continue using my former company's pads.
Any helpful links or phone numbers will be very helpful. I've google for an hour without any results. And I tried various phrases such as engineering pads, engineering paper pads, quadrille engineering pad....
Thank you in advance for your help.
RE: Where buy/order personalized engineering pads?
Contact Linda Berry [lberry@sbforms.net]
Service Business Forms - 615-242-FORM
I just ordered 1000 from them with a CORRECT grid and it cost me somewhere around $150 which I don't think is too bad. They charge a minimal amount to modify the title block, etc.
Tell her that Brad Davis gave her number -- maybe I'll get a discount on my next order!!
DBD
DBD
They're likely tob be local and willing to do the job.
Try googling words related to stationary rather than engineering pads. It's stationary suppliers who'll provide you with what you want.
Try googling words related to stationary rather than engineering pads. It's stationary suppliers who'll provide you with what you want."
That's where I got the contact that I listed...
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I'll call the place that DBDavis recommanded. Thanks once again.
well said, I do the same. With acad you can do it in any format, scaling, shading you like.
I also have a couple done up in excel (not quite as good, but obviously doesn't require the cost of acad).
and great prices - the cost of paper & toner - about 3 cents per sheet or so.
DRW
http://www.nebs.com/NASApp/nebsEcat/index.jsp
We use this particular pad:
ht
I get the type that is 1/8 of an inch grid so that I can draw to scale free hand without needing a scale. I also get the type that is numbered and when making copies, the grid lines do not show up. This makes a cleaner calculation sheet.
Good luck.
Lutfi
