95% Ar - 5% Hydrogen vs 100 Argon cleaner??
Is the 95-5 a cleaner shielding gas as well as an aid to penetration?? I am welding 300 series SS to each other. GTAW, .060 wall. Where can I find onfo that educates me on these variables??
RE: 95% Ar - 5% Hydrogen vs 100 Argon cleaner??
htt
Good link from metengr
We use 95/5 in plasma torches. It is hard to use as a shield gas becuase is has better thermal conductivity and my reduce penetration, but yes, it is cleaner.
5% H2 is not a saftey issue. You are below the flamability limits, and by the time you add enough air to have some O2 you are even lower.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
