draglink location and affects
What sort of pros and cons are there in relocating a draglink forward or rearwards from standard position. This is on a car with steering gear located forward of the axle line?
Standard is with the draglink located behind the outer tierod ends by several inches.
RE: draglink location and affects
That'll change your Ackermann, and your toe vs bump curve.
Cheers
Greg Locock
