Position tolerance from a single datum
The axis of one hole, which is the datum, to another hole.
The feature control frame says 0.1 to [-A-],[-B-],[-E-]. A 42.5 Basic leads from diameter A-E to the perpendicular center axsis of the other hole.
For purposes of capability studies does the 0.1 mean the entire tolerance zone? And if that is the case should the delta between the true center and the datum be doubled.
RE: Position tolerance from a single datum
http://www.tec-ease.com/gdt-tips.htm
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
