stray line in drawing
When creating a drawing of a fairly large part or one with a thread cut - I occasionally get some stray lines/curves that appear.  None of them are selectable to "hide" and there doesn't seem to be any feature related to them directly, its seems that they are a result of a complex model or surface (high memory usage driven error perhaps?).  Has anyone dealt with this or found a solution?
RE: stray line in drawing
Try:
View/Hide all types
Does that fix the issue?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
nope - its seems to be an anomaly related to the model.
Have you tried increasing the image quality model and/or drawing?
 TOOLS - OPTIONS - DOCUMENT PROPERTIES - IMAGE QUALITY
Remember...
       "If you don't use your head,
                   your going to have to use your feet."
No solution, but I see 'em sometimes.  If I turn off cosmetic threads, they go away.
In the model, right click on Annotations in tree, unselect everything.
Chris
FAQ559-1100
FAQ559-716
Tried them all - still no luck with this one.  It seems to be an artifact from a surface fill as if I change it's geometry the entity changes as well.
  I have an issue on some drawings, where the plot has distorted copies of sketches drawing in a very fine line. This with Version 2004 r3.1 plotting to a HP Designjet 130nr.  I've had it happen on two different drawings created from separate designs.  On the ones where it happens, it does it consistantly.
  Never found a resolution, and just accepted the presence of the stray lines.
Joe Dunfee
