binary addition of 2 bytes
dear forum,
I need to implement a simple routine that performs binary addition of 2 bytes (stored as 'char') (the method is used for calculating checksum for an wireless comm)
e.g.
char a = '0x41';
char b = '0x52';
'0x41' 1000 0001
+'0x52' 0101 0010
='0xD3 1101 0011
does anyone have some sample code available of any links.
best regards
doneirik
e.g.
char a = '0x41';
char b = '0x52';
'0x41' 1000 0001
+'0x52' 0101 0010
='0xD3 1101 0011
best regards
doneirik
RE: binary addition of 2 bytes
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
TTFN
main(){
char a,b,c;
unsigned char d;
a = 0x41;
b = 0x52;
c= a + b;
d= (unsigned char) a + (unsigned char) b;
printf( "c=0x%x\td=0x%x\n",(char)c,d);
[richs@b52bdhcp1 junk]$ vi junk.c
[richs@b52bdhcp1 junk]$ !cc
cc junk.c
[richs@b52bdhcp1 junk]$ !./
./a.out
c=0xffffff93 d=0x93
That what you are looking for?
Cheers,
Rich S.
Dan
Owner
http://www.Hi-TecDesigns.com
sorry...I was too fast...
I´m programming in Visual C++ .Net 2003.
Any C code will do...
regards
eirik
richs
has already given you the answer, although you might have an overange problem and might want to store your answer as a uint16. If you are developing in .NET and plan to use a small uP target, you might want to check the sign assumption of your target char, or better yet explicitly use signed char (or unsigned char) in all places.
How did you get 0xD3 in your original query?
Do you need to mask out the top bit and set a parity bit accordingly?
