Pressure test, N2, He or Compressed air??
What are the biggest pros and cons about the media when low pressure (225 psig) pressure testing?? We are an OEM and have some cells that use Nitrogen, others use Helium leak detectors while others use the air under water method.
RE: Pressure test, N2, He or Compressed air??
What you use really depends on your process. If I were leak checking something for liquid service, then I would probably spec out air. Whether the air was dried or not would depend on if the process is moisture tolerant.
For inert gas service, it would depend on how leak free you need it. To me, this would depend on the impurity level of the process. For gases with less than 100 ppm total impurities, I would use helium. Leaks missed with using air can still contaminate the process.
For toxic or flammable gas service I would only use helium period.
It would help if you could explain your process in more detail. The materials of construction can also make a difference.
Helium
Pros: Smallest molecule available. It there is a leak, this will find it. Now how you check for the leak is a totally different matter.
Cons: Expensive
Nitrogen
Pros: Similar properties to that of air. If moisture contamination is a concern, this is better than standard air. If your shop is not set up to handle drying shop air, then this is a good alternative. Even poor grade nitrogen is generally fairly dry.
Cons: More expensive than shop air.
Air:
Pros: Cheap and readily available.
Cons: Moisture contamination.
Hope this helps,
Chris
Good comment about the contamination and Dryness. I had not thought of that. How does Mass-flow or pressure decay compare to the others??
However, your applications are mostly liquid and freon. The freon is relatively low pressure and liquid systems are easy. I would consider dry nitrogen with a pressure decay. If you monitor the temperature of the gas, you can actually calculate a leak rate.
All this being said, it can really all go back to marketing. What value is given to a helium mass spec system in the customer's view? For anything flammable or expensive, I would think that the helium method is required. There are some mass spec units that are capable of measuring leaks down to 10e-9 cc/atm (think the units are correct but I can only rememeber the number for certain!) This is semicondutor purities and levels (impurities less than 1ppm or better). Bubbles can only give you a 10-3 cc/atm.
It seems to me that you need more information from engineering who may, in turn, need more information from the marketing folks.
This would be much safer, faster, and cheaper. If contamination on site (oils or corrosion from water use) isn't a problem you may want to look into this.
the use of the word "withstand" makes me believe that this is more of a structural test than looking for 1ppm of leaking. That noted the use of compressed gasses is very dangerous. If any of these items are large in volume you could be looking at a little bomb.
Leak checks should be done up to the design operating pressure...not 1.5 or 1.3 or even 1.1.
I have been working in the high pressure gas industry (read "high pressure" as 3,000 - 7,500 gas compression). It is critical that systems be structurally tested by hydro.
Hydro is not a leak check. Special precautions are always taken when doing pneumatic leak tests. First of all, I normally start with a 50 psig "gross leak" check. This is where you find valves that have been left open. The hydo normally finds any other "gross leak" problems. Then I take the pressure up in 250 psig increments looking for leaks at each stage.
I would reiterate about getting with your engineering dept so that they can determine the appropiate test. It sounds to me like they left something off the print.
I have no idea how large these units are, or what "cells" are, but I wouldn't be pressure testing anything pnuematically if I could avoid it!
If you're only doing sensitive tightness checks, then keep the pressure as low as possible and with air and nitrogen, use soap solution at joints to test for leaks.
With He... well, good luck, those little molecules squeeze through anything. Sniff the joints with the detector.
The stored energy is the prime danger in a pneumatic pressure test. Tread warily.
Cheers
Rob
