CAN bus on a SLC/control logix
Does anyone know where I can find a can open module for a SLC 5/05 or a control logix plc??
How about a way to communicate with CAN open device from either one of these plc's. I'm leaning towards a gateway, but I don't know weather or not this is feasible. I don't know much about CAN bus, other than that's what DevicNET is based on.
HELP!!!! any and ALL suggestions/questions greatly appreciated.
Schick
RE: CAN bus on a SLC/control logix
Try this.
http://www.interfacebus.com/Design_Connector_CAN.html
I am curious about what you are trying to achieve that is not already done with Devicenet.
I have found communication to other devices (RS-232) using Devicenet to be pretty easy and straightforward.
I hope this helps.
Jonesy-
Actually it's a meter running CAN OPEN. Unfortuantely, I'm not enough of an electrical guy to understand most of the info on that link.
I did find a company who makes a gateway that would communicate between Ethernet, controlnet, etc to CAN OPEN. I'm hoping the comms occur quick enough that there isn't a problem.
schick
