Bridge replacement
Bridge replacement
I need to replace a deteriorated, single-lane, 45'span bridge used by coal trucks. Replacement needs to be completed quickly to minimize traffic interruption. What is the best choice considering project cost and down-time? I was considering pre-cast/pre-stressed concrete. Any suggested suppliers for southern WV?
RE: Bridge replacement
www.acrowusa.com
Ask for Mark Joosten or Scott Patterson
Those truss bridges are marketed for their rapid constructibility (or to replace a cherished local historical bridge that just couldn't be saved; those trusses sure are cute). I don't know how they compare on a cost basis to beams (or flatbed railcars). There are a number of companies that make them. Besides ACROW, there's US Bridge in Cambridge, OH (http://www.usbridge.com/ ), Steadfast in Ft. Payne, AL (http://www.steadfastbridge.com/ ), and many other worthies with whom I have not yet had the pleasure of doing business (so don't take this as an endorsement of the above companies on the part of whoever it is you assume I work for).
Hg
Eng-Tips guidelines: FAQ731-376
Continental Bridges.
Both of these are pre-fabricated metal truss bridges that can be designed to fit your application. Typically a local firm will do the coordination with the roadway and geotechnical work for the abutments. The rest is done by the bridge suppiers.
Look for them on the web.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
US bridge has fabricated many bridge that installed all over WV.
AISC Certified
US Bridge htt
Vita sine litteris mors est.
OK OK! I for one liked your idea of the rolled steel beams. A 25mm thick steel plate on top and a traffic rail welded to the side and a 15m span bridge easily achieved. The only minor problem is that the beams will probably be suppplied in 12m lengths so joints required.
Looks like I owe you an apology....didn't see that bridge manufacturer recomendation (2 no less) in your paragraph!
Sorry!
Qshake
Hg
C'est la vie!
