bonding steel to steel
Which bonding material would you select for  attaching a flat plate with a bumpstop on to another flat plate. The loads would hopefully be only compressive shock.
RE: bonding steel to steel
I forgot to add I'm in the UK
"No More Nails"
ie any RTV type compound.
Cheers
Greg Locock
Or maybe even some form of tape, like 3M's VHB tapes.
http://www.3m.com/vhb
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I don't have time to pickout a specific adhesive but we use a lot of loctite products for bonding dissimiliar materials.  Check out the links and loctite has a great technical staff.
http://www.loctite.com/int_henkel/loctite/entry.cfm
http://www.industrial-adhesives.com/int_henkel/ai/channels/index.cfm?pageid=12
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
scarecrow 55
Do not go for an epoxy type adhesive  ---- too brittle and very soon fail. Clean both surface with grinder or shotblaster then use a Belzona " magic rubber" type compound. With suitable primer it is your best choice. I can check the product list and advise exact type if needed.  Devcon do an exact equal at half the price.If you do not know these products then put a thin veneer of rubber between your surfaces and glue it with a propriety rubber adhesive like SC2000 from TipTop Rubber at Leeds,  Call me if neede further help      DW
Thanks everyone, but we've changed the design and are using a bolted stop.
I'll bear all those comments in mind for future though.
