bearing database
bearing database
bearing database
Hi all
can somone  please tell if there is a bearing database, that can downloaded.
Thankyou
RE: bearing database
Hi you did not say which brand bearings, but if it is NTN or generic info that you are looking for, there is a complete catalog of info etc.  Take a look at http://www.ntnamerica.com/pages/products.htm
If it is another brand let me know and I will check it out for you.
C. Hugh (www.Hatch.ca)
Thanks Hatch
it was very helpfull the site you indicated .
one of the problem i'm faced with is i do not have a good  bearing database: SKF,NSK...
SKF has a bearing database called "Atlas" consisting of thousands of bearings from all the major Bearing manufacturer's - usually sold for a few hundred dollars - you might be able to talk an SKF Condition Monitoring sales person out of a copy.
Go to the following link
http://www.efftek.freeserve.co.uk/
Select your language.
Select "Downloads" on left side of screen
Select "Bearing Fault Frequency Database - 26000 bearings (510kB)"
