Material Selection
Material Selection
Any help to find T-P range of the following tade material names:
LTCS (low temperature CS)
KCS (Killed CS)
I have a little background about the material properties and selection in general as my field is not much related to such interesting area.
Any help is appreciated
Regards to all
KCS (Killed CS)
Regards to all
RE: Material Selection
There is nothing called T-P (I presume you mean temperature-pressure) range. While selecting the material in a pressure construction, you must know the allowable stress value at your design temperature. The allowable stress values are provided in ASME Sec. II D. If you refer to the Notes given against the stress values, you will also see a cautionary note about use at high temperature.
You can check stress values for SA516 Gr 70 which is KCS.
