overlapping vs. switching neutrals
In a automatic transfer switch application, the generator is a seperately dervied system at 480V. The transfer switch installed is a 4 pole with an overlapping neutral.
Questions:
1. Can an overlapping neutal be used with a separately derived system where overlapping is only momentarily (make before break)
2. What are the pros and cons of using swicthing vs. overlapping.
RE: overlapping vs. switching neutrals
Overlapping "is" part of the switching, where it momentarily overlaps but source of neural gets switched. There is no difference between the two.
Or in other words when a neutral is 'switched' it is always done via overlapping neutral. This is to avoid system being left without grounding even for a moment.
