Extract segment from imported IGES
I generated this IGES file of a parabola (http://peu.net/temp/ref2.igs), and I want to create a more complex part using the inner parabola segment to create a sketch.
How can this be done?
RE: Extract segment from imported IGES
Hi PEU,
If I understand your question....the only thing you need to do is to insert a NEW PLANE using the segment you want to use as reference, then start a new sketch on that same plane, select the segment you want to use, then use CONVERT ENTITIES, then you will have an IDENTICAL SEGMENT,
OR
You can use 3D Sketch CONVERT ENTITIES, but this command is limited in SW2005, SW2006 is more complete for 3D Sketch.
Hope this is answers your question..
Colombo75
Industrial Designer
SW2005 SP4.0
Hi Colombo,
I tried for the last 2 hours but I dont quite understand the process. Thanks anyway :)
You will need to use the Intersection Curve feature.
http://img108.imageshack.us/img108/4674/intersectioncurve0yc.jpg
2D Sketch Method:-
1) Select (or create) a plane which intersects the portion of the parabola you need to generate geometry from.
2) Select the Intersection Curve icon or Tools > Sketch Tools > Intersection Curve
3) Click on the surface you want to generate geometry from.
3D Sketch Method:-
1) Select a surface
3) Select the plane
4) Click on the surface
Either way, the geometry should  automagically appear.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
peu,
I tryed to open in sw2001 as iges and it didn't come in very well so  opened it in ProE.. came in fine.. I exported it as a stp file and it then loaded into sw2001 fine
I can send you the step file, but I am not sure how that is done on this forum
I had trouble opening it in SW04, but SW05 had no problem.
cadcamguy ... you have to have the file reside on a webserver & then post the URL here. eg: PEUs igs file is in the temp folder of his http://peu.net website.
Woohooo, that did it CorBlimeyLimey. Thank you very much and also thank you for all the posters for helping me!!!
a new day, a new tip learnt :)
peu
CorBlimeyLimey,
I had gotten the igs file from his site.
But in order for me to send something to someone here, then I need to upload it to my lil' Isp space and provide the link..correct?
There is no commonspace to upload something here?
I did notice the imageshack site...but something in a name tells me that's not the place for a step file
thanks
"I need to upload it to my lil' Isp space and provide the link..correct?"
Yes.
"There is no commonspace to upload something here?"
Unfortunately not ... too much of a security risk & too easily abused!
Correct ... Imageshack can only be used for bitmap files:-
jpeg, jpg, png, gif, bmp, tif, tiff and swf and to a max file size of 1MB.
Thanks CBL,
From someone who spent some time in the Fens of East Anglia
I'd buy you a pint if I could.
Hi PEU,
"...and I want to create a more complex part using the inner parabola segment to create a sketch."
In simple words this is called a profile....that's not what I understood from your question...sorry...
Glad you still got it..
Colombo75
Industrial Designer
SW2005 SP4.0
