Concentration of Propylene Glycol in cooling water
Does anyone used and measured automatically, the concentration of Propylene Glycol in cooling water system?
Right now I only have a portable device that gives the temperature of freezing, but I’d like to have an automatic controller of the concentration.
Thanks in advance
Aharon
RE: Concentration of Propylene Glycol in cooling water
Most of these cooling systems are closed systems so that there is no regular makeup of water. The systems are filled on a batch basis.
A refractor is what you need, commercially available fromm scientific instrument suppliers, a simple one will give % glycol, mono & prop glycol on same instrument.
mrushy
Mrushy,
Can you recommend on specific supplier/vendor for this instrument?
Aharon
Aharon
Bellinghamandstanley.com
They have a UK and US address, I have only purchased in the UK.
mrushy
