Flexible pipe connection
I'm looking for the possibility of flexible connections to a gas header for a compressor test facility. As not all the compressors have the same layout, the positions of the suction and discharge lines differ. Instead of welding new pipes with flanges each time we are now looking for flexible connections. The header is 12" and the pressures are around 10-30 bara. There may not be any leakage as this will influence the compressor test. Anybody an idea?
RE: Flexible pipe connection
You can use the ball joints to make swivels. But I think yogibear1 has a good idea using the flex hose, if you can get it in your size.
http://www.hyspan.com/
