Recapturing evaporative losses from cooling towers
Does anyone have any tips on processes for recapturing evaporative losses from cooling towers for reuse elsewhere? Looking at reducing water use in shopping centres. All suggestions most welcome
RE: Recapturing evaporative losses from cooling towers
www.SlideRuleEra.net
SPX Technologies is commercializing a new technology called the Air2Air Water Conservation Unit that offers another route to reduced water consumption. “The A2A unit is an additional heat exchanger mounted in the upper portion of a standard cooling tower that recondenses and returns up to 30 percent of the evaporated water to the cooling circuit,” said Ken Mortensen, manager, environmental programs, with SPX Cooling Technologies. “Compared to a standard tower, we have to install a larger structure and a series of patented fill packs. There is also slightly higher fan power usage to draw in the additional air to recondense the water.” Based on field studies conducted by SPX, the average power usage may be in the range of 113-300 MWh per MCF (million cubic feet) of recovered water.
When incorporated in new tower designs, the addition of the A2A unit may add 10 to 50 percent to the installation cost of the tower. “With the added ability to collect the recovered, pure water in a side stream, the A2A unit costing stacks up incredibly well compared to other pure water production units like reverse osmosis,” said Mortensen. “It is also an environmentally responsible solution in that it allows plant operators to utilize waste heat from the plant to generate pure water.” SPX has completed validation testing of the unit at its Kansas City research and development center and is planning the first scale field installation, on a heavily instrumented tower, at an operating power plant later this year.
http:
