High Voltage Comparator???
I was wondering if anyone knows a company that produces a rail to rail comparator that can be supplied by at least 48V.  I would rather not use an op-amp because they are very very slow compared to a good comparator and the comparator has the open collector output that i need to decrease the components in my circuit.  Thanks for any help.
RE: High Voltage Comparator???
What are the specs you need ?
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
I'm trying to make a basic switching power supply with a 48V supply rail-to-rail output comparator.  An open collector output would be perfect.
What wrong with using resistor dividers?
TTFN
Agree with IRstuff, resistive dividers on the inputs, and use the comparator output to drive a small MOSFET with open drain. That just about removes any real practical voltage constraints on either input or output. With a bit of detailed design it could be made quite fast.
I am currently using a resitor devider-esque circuit with a FET.  We would really like to use a nice comparator to decrease board real estate and increase response time.  Comparators are in ns where the current system takes a couple us to become nice and stable.  Just a thought though.  These comparators would really help out for the next project.  I really need a comparator though, NOT and op-amp.  Thanks.
So why not use a comparator with a resistor divider?
Or, use high speed op-amps.  The typical switching power supply is only running in the sub-MHz range.
If you're that desperate for board space, then maybe you need to look at getting a custom hybrid.
TTFN
