shrinkage formulas
shrinkage formulas
I need to know the functional diffrence between the shrinkage formulas.
1+S
1/(1-S)
(S stands for the shrinkage factor)
By functional I mean where or when to use the proper formula
Any other info about shrinkage formulas would also be helpful
1+S
1/(1-S)
RE: shrinkage formulas
The 1/(1-S) formula is used to take the shrink away (or to scale down) to give the nominal or real dimension. Since shrink is multiplicitive, you don't multiply the above example by 0.997 to take the shrink away...it would actually be 0.99701 due to the formula.
Visit geocities.com/cursogratis
