Pipe tolerance
Pipe tolerance
Pipe tolerance
There is a fabrication tolerance of 12.5% on pipe. In stress calculations the wall thickness (sch 40) must be reduced by this amount. My question is about stainless pipe. Does this tolerance also apply to 5S, 10S etc
RE: Pipe tolerance
You should check with the applicable pipe standard e.g. A312 refers to A999 which says -12.5%. I think they're all the same but you should check.
RE: Pipe tolerance
Large diameter pipe fabricated would not use a 12.5% tolerance.  The wall thickness tolerance would look more like a plate tolerance.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
