NX2 Assembly Constraint Precision
There should be a parameter about the precision of the 3D constraints. Suppose there is an off-center value of 1E-6mm in any direction between a shaft and a hole. One can still mate these two bodies regardless of the minimal off-center value.
In Mechanical Desktop there was an assembly parameter for this. By adjusting it, the sensitivity of 3D constraints can be changed to desired value.
I wonder if there is such a parameter in UG NX2.
Best Regards
