Attached Legs to 2:1 Elliptical Head
Is there any design considerations to take into account when attaching legs directly the bottom head instead of attaching them to the shell. I want to use either channels or angle supports to attach the legs to the head. The vessel itself is an API 650 tank that is atmosperic.
RE: Attached Legs to 2:1 Elliptical Head
Brian
Pressure Vessels and Autoclave Systems
www.mcabeeconstruction.com
The above comments/opinions are solely my own and not those of McAbee Construction.
Assuming you work out some way to adequately analyze the tank, there's no reason you couldn't put the legs on the elliptical head. I've noticed a bunch of little cone-bottom tanks on farms, and most of them have legs attaching to the cone with circular ring.
