Power Distribution
Power Distribution
Main service is 400 amps. Would like to break it down to 2-200 amp breaker panels. I plan to then send 100 amp over to the pole barn and 100 amps over to the horse barn. The rest of the power will be used for the home. Is there anything special I need to do and what could you recommend. Can I juct conntect my cables from the 200 service main breakers up to the 400 amp meter box and use 100 amp breakers to distribute over to the barns? Thanks
RE: Power Distribution
