Drawing table
Drawing table
Hello Everyone:
Does anyone know if there is a way of getting the data from a drawing table in catia to be saved as a CSV format.
RE: Drawing table
I'm told you can convert a csv into a CATIA table, but it's made with no link.
But, if you create an Excel spreadsheet first, you can copy & paste it to a CATdrawing. And you can double-click on the table to re-open the spreadsheet and edit it.
RE: Drawing table
I need to go the other way, catia table to CSV. I guess I'm out of luck.
RE: Drawing table
we do have some script to go CATIA Drawing Table <=> Excel
very usefull as editing is much more ...easy in XL.
RE: Drawing table
Thanks for the suggestions but I dont have any experience creating scripts. One more thing that I still need to learn!
RE: Drawing table
Do you know of any available script for transferring BOM from CATProduct to Excel. My company has an specific ISO formatted .xls documents with designated location for information like: quantity, part number, nomenclature and material. I'm not a catia script guru but I know this should be possible to achieve through scripting.
Darek
RE: Drawing table
Sorry but I can not give you our code.
You can find plenty of info in forums / online doc.
you can even ask in forum for some help to correct (not create) your code, we will help you.
RE: Drawing table
Or you can use another software which can capture text from screen (for example SnagIt or something similar).
Fernando
